MLo3
- Pittsburgh, Pennsylvania
I have a 2005 AR230 and am having issues with the port engine, starboard runs fine. Engine works in neutral but when I try to give it throttle, the boat vibrates and rattles with no acceleration. My knowledge is limited but it acts like a jet ski with something stuck in the intake.
I pulled out seized cleanout plugs and replaced with the repair kit. I didn’t feel anything inside when I replaced the plugs on either side. Previously, the boat had done this before but with some throttle manipulation, the issue would resolve itself. This isn’t the case anymore.
My next step after consulting the forum is to call a mechanic. Any suggestions are worthwhile. Could this be a throttle cable issue? Thank you!
