Gym
- Falmouth, MA (Cape Cod)
- SX
[USERGROUP=9]@HELP[/USERGROUP] on the water at the dock. Port engine starts but quits as soon as key is released. Ran the boat for about 20 minutes today after launch. Noticed port tack was intermittent. Put someone at the helm while I looked at the wiring harness in the aft starboard locker. As I touched the harness the tack came alive so I knew I had a bad connection or corrosion. Boat ran fine though.
Back at the dock I took the port connector apart (10 wires) and sure enough the red wire connector was corroded apart and was only making occasional contact. I took the red wires out of the male & female sides of the connector and wire nutter them together until I can buy the correct lugs. Now, it will start but quits as soon as I release the key. If I hold the key in the start position it will continue to run. I checked all the usual stuff like ECU fuses, hatch & lanyard switches. Starboard engine runs fine. Thoughts...
