Neutron
- New Bern, NC
Working on an 2011 242 and have a weird engine stumble/ miss at random times. Seems worse when at full temp.
It does it at any rpm range. It is like a a cylinder drops out for a second then recovers. Only on port engine
What i tried:
Swapped all coils,plugs, injectors and rail, fuel pump with starboard engine.
No fault codes
Turns out this engine is has been replaced. Not sure the history on it. Owner just bought this boat from a dealer in PA. He is going to try and get some info on it.
Didn't do a compression test, or leak down test.
What i tried:
No fault codes
