dzeppos
- Coto de caza, CA
- Limited S
After getting the wood chip off my boat (needed a local mechanic to do it), and all excited to try out my Super Magnum AK that got installed at the same time (already had the Lateral Thrusters put on earlier this summer) i was going to rave on how it was the perfect combo for a 24" yamaha boat. And it was - felt like there is nothing better than a 242 with both of these features.
Last run on the lake - after a few hours of wakeboarding and wake surfing - and then cruising back to the dock - the steering felt sloppy- like i couldn't handle the boat. Then my port thruster was stuck in the open position.
Well - wasn't a rock - but the entire housing came undone after I pulled it out. Worse, the lateral thruster was dangling - and the bracket holding it was bent, and the clip holding the throttle bucket had snaped off. the Magnum AKs were fine. I didn't back into anything and hit nothing forward moving - all deep water lake.
I'm thinking two things - that the bolt housing the LT came undone (but I put those on about 30 boat hours ago earlier this summer - no issues - but maybe not?)
Or when they pulled the pump to get rid of the wood the other day- maybe it wasn't put back in right with the bolts, or maybe when they adjusted the steering cable when the Magnum AKs were put on? Does the LT needed to be unscrewed in any way when taking out the pumps?
I'm not looking to blame anyone - just figuring what to fix and prevent this from happening again.
Here are some pics showing what snapped off the throttle cable link to the port bucket and the bent lateral thruster.
No
(and I had such a great day until the end! - its all good - just having some bad luck!)
No
