Chip F.
Jetboaters Commander
- Schuylkill Haven, PA
- SX
First a little history.. last fall both my pumps were pulled by the dealer in order to repair several gel coat cracks around the mounting bolts of both along with gel coat cracks at my rudder attachments.
Tonight I took the boat out for testing and discovered severe cavitation on the port side as I increased the throttle to it and then the RPMs pegged. If I babied the throttle I was able to get the boat up on plane . I checked the clean out plugs and reseated both but I know that both were seated properly.
I came home and looked at a couple threads on the issue and what I’ve concluded is that the impeller clearance by eyeball looks tight but I did not put a feeler gauge in there. It looks like the tunnel has gaps and that’s what I think the issue is. Looking for experienced opinions. Here are some photos:
