Power converter
I have used one that just clips onto the batteries but never permanently installed one to the boat. I just pull it out and use it when needed.
I have a 1,000 watt inverter like @robert843 mentioned. My tube inflator is 110v, so I use it for that.
What are you wanting to power?
I have not used an inverter in our boat. I do have a 1,500 watt inverter that was used for jobs early in my house construction.
I have always been concerned about the risk of electrocution from using 120 on the boat. For example I dropped the tube pump in the water today while I was in the water using it. If it had been a 120 volt pull without a GFCI it would have shocked me. 12 volt has limited ability to conduct through the water so it did not bother me.
If you are going to install and inverter I would use a marine inverter and install it as high as possible.
I'm not wanting to power anything specific. .. I don't know that I need one. I saw one on amazon and wondered if others have used one and for what applications. My inflator runs off of my battery.
Most anything needed in a boat will come in a 12v version, That's why the margarita blenders come in 12v versions. Leave the 110 out of the boat unless the need comes up.
It is safer, and way more efficient then converting. . . . .
