Emiel
- Other
- Other
Hello,
Thank you guys for having such a great fourm,
I hope you can help me with the problems with our jet boat,
It is an Ribtec boat with an inboard Mermaid /Ford Diesel engine,
with an for me unknown type of Jet, there is no kind of marking or plate on the jet.
Got the boat from internet, was an service boat for a big yacht, and only used by personel to go for grocceries, it had been out of use for approx. 10 years.
At our first test drive, the boat was not going very well, there was some force when taking off, but at speed there was no power and the engine just would rev but nothing happens besides a lot of shaking and noise.
we where not getting speeds above 10mph.
So we took the jet apart
There was a lot of space between the impeller and the wear ring, the glant seal was leaking and the bearing was gone,
so a new seal and bearing, adjusted the impeller to .30mm, and a new paint job, the inspection cover seal looks okay, but i am thinking to bond it shut, so it is airtight.
So new looking jet, new test, But the problems stays, enough force from standstill, but the top speed stays around 10-15mph, and not getting in to plane. giving more throttle just gives more revs, and noise.
It is just like the jet doesn't get enough water, and starts pumping air.
There is a grate installed, but don't have a picture at hand right now, but no ride plate.
could this be the problem, did a lot of searching but could not find an solution.
if you need specific pictures feel free to ask, and i will do my best to make them.
Thanks
Emiel
The Netherlands.
Thanks
Emiel
The Netherlands.
