Projects so far - good week of holiday time spent!
Derek Fosbury
Oakville, ON
242 Limited S E-Series
Spent the past week up at the cottage both enjoying and working on the boat. I got about an hour a day of work on the boat in before the little monsters emerged from their caves and demanded water time :). But still managed to finish up some work that I had started on previous weekends, and started & finished some new ones.
Projects completed:
1. treated gas tank hatch with mass loading material (dynamat equivalent) and foam sound barrier
2. added life-jacket hanger in the helm (thanks again Julian!)
3. added wire shelf in port storage/head
4. treated walls of underseat storage areas (cabin and bow) with mass loading, then put original carpeting back on with 3M spray glue. Also did underside of ski locker and engine side plywood bulkheads.
5. moved strut mounting location on ski locker so it opens all the way
6. replaced stock db651 speakers with MM651UM
7. added additional cabin speakers by helm and port passenger seat (using db651s for now till additional MM651UM pair shows up)
8. installed JL Audio xd800/8v2 amp
9. installed ProMariner 2 bank 20 amp charger and modified DVSR to use storage mode, as well as installed exterior thru-hull power inlet
10. Named the boat :). "Monster Mover 2.0"
Wow. You got a lot done. Great work, nice and clean.
