waternutt
- Panama City, FL
- Chaparral
- VR
I recently had to replace the exhaust manifold on one of my engines due to a water outlet nipple being completely corroded and falling off. I do use it in saltwater, but I am the original owner of the boat and flushed the exhaust after every outing. I am beginning to wonder if my flushing procedure is incorrect or something else I am missing.
My flushing procedure seems similar to most on here: connect hose, start engine, turn on water, turn off water, turn off engine. I typically flush for no more than 2 minutes (1 min with freshwater, 1 min with saltaway) with the engine at idle. After the water is off, I will finish up by giving the engine a couple quick revs to get out any last water.
Looking in the Rotax operators and service manuals, they both mention running the engine about 20 seconds at a fast idle between 4000-5000 RPM. Does anyone due this step?
I really am curious what caused that level of corrosion and I would like to prevent having to replace another exhaust manifold.
