David Decker
- Atlanta, GA
- 242 Limited S E-Series
I am running 100 watts rms to my stock tower tweeters and so far they are doing fine. Figured if I blow them I can upgrade then but so far no need.The only thing I wish I had done with the 8 speakers on my boat is to install an EQ/Fader so I could more discreetly control the volume at each pair of speakers. In both your options, front to rear fading looks to be less than useful. If you ever put full tower cans in, you might want to do it then.
Looks like you should have plenty of power....just wonder if those tiny tower tweeters can handle 50w?
I am having a hard time understanding the wiring. From the pic below, there are 4 channels. From your findings and a few others, the entire boat EXCEPT the rear cabin and the swim deck speakers, are wired in parallel. What am I missing? Including the tweeters, there are 8 speakers and only 2 pair are wired in series. The harness below only shows 4 channels (4 pairs of wire). Please explain how you think each speaker is powered based on the attached pic of the harness. Thanks.I will probably add a level control + second small amp someday to power those swim deck speakers. They are OK for now, but the cabin+bow speakers sound maybe 50% louder -- it is hard to tell exactly. You can easily hear the swim platform speakers near the back of the boat, but it is also obvious they aren't as loud as the cabin speakers. This is OK while underway, but I might want more power when in the water or on the swim platform. The tower tweeters are just about right - I thought they were too bright before, but now seem balanced pretty nicely.
I found out that the bow and tweeters are wired in parallel, but the cabin and swim platform speakers are wired in series! I ran new speaker wire for the bow and cabin speakers to the amp. I just unplugged the stock bow speaker wires and let them hang there - that was easy. But for the cabin speakers, I made a couple of short male-to-male "jumper" wires and connected the stock cabin speaker wires to them - this lets the head unit power only the swim platform speakers. I don't know why they wired these speakers in series -- maybe to protect the head unit?
No other changes to wiring were needed, and it is very easy to go back to stock wiring if desired.
I did find that the Polks have one normal-width speaker lug on the back and one very narrow speaker lug -- I had to search around a bit to find a narrow connector for the new speaker wires and narrow lugs for the jumper wires.
Perfect. Great illustration!
