mkcawcutt
- Limited S
Hey All - I've got a 2018 LTDS - do you all tow/pull people with the bimini up? If so - do you run the tow rope through the zippable hatch onto the tower? - OR -
Do you run the tow tope on top of the bimini? Curious as I've experienced rubbing or the tow rope hitting the bimini in both situations. Am I doing something wrong? Thanks all!
Wake-surfing isn't an issue as the rope is obviously shorter - but for tubing especially - wondering what the proper setup is while running with the bimini up.
Cheers!
M
Cheers!
M
