jdmackes
- Other
- Other
I just purchased a Polaris Le2100 with an Optimax 250 M2 drive. I was told by the the place that previous owner serviced his boat, that everything was done when it comes to winterizing and lube last year. I wanted to take a look at it myself and I also wanted to get a good luck at the impeller and wear ring, but I've found that the pump lube drain plus is seized up. The vent one was a little tight but that opened up with little issue. I've tried using pb blaster and an impact screwdriver tool, using a breaker bar (that just stripped the plug more than it was before) and using an impact gun with a bit (but that made the bit explode). Can I use heat or would that damage anything within the pump? Does anyone else have any ideas? I'm questioning if they really could have done the lube if this plug is so stuck (and two of the torx screws to necessary to remove the trim plate are so stripped I thought they were hex screws, but I don't see a reason I couldn't use heat on those).
