MidnightRider
- Zumbro Falls, MN
- Malibu
- Wake
First things first, many thanks to @Mainah for putting together these kits and making them available. It gets my "coolest" mod so far on my boat, not only from me but from my teenage son.
So being me I can't just leave well enough alone and did a slight modification to the kit before I installed. I wanted to move the key ignition switches to a new location and install the push buttons in the original key switch holes, to make the push buttons the main focus front and center and the keys off to the side.
The kit comes with 5/8" push buttons but the key switch holes are 3/4". ULINCOS sells a pretty much identical 3/4" push button (U19C3) and socket/pigtail. Unfortunately the socket configuration is a bit different so I did need to cut off the socket the kit comes with and re-wire the socket for the 3/4" buttons - easy-peasy. Comparing the socket pin outs showed that the pig tail wire color designations are the same for both, so just matched up the colors and spliced the new sockets on. After that it was business as usual and the kit is pretty much plug and play, dead simple install. Only other thing I had to do was to create an extended key switch wiring harness for both key switches so they could be relocated to their new location over by the throttles.
Dry run produced perfect results - both engines fired up according to the pre-programmed sequence and shut off with the Stop button - love it! Can't wait to get it on the water where it will get very practical use besides just feeling/looking cool.
Again, thanks to @Maniah and if you are thinking about this mod get on his list and just do it.
New pig tails installed (after this pic I did follow the kits example and seal up the backs of the sockets).
Extended key switch wiring harness.
Controller installed (yep my tachs are inside my helm - see my post on my ridesteady install to see why)
Push buttons installed in original key switch holes
Keys relocated over in front of throttles.
