zackmorris
- Winter Springs, FL
- FSH Sport
2006 sx230 HO
Just replaced plugs
Filter is fine. No oil saturation.
Checked throttle position at full throttle on both engines and both are at max position- I can’t force the throttle any further on either engine
the starboard engine is only hitting 9.8k rpm when running and wide open. The port engine hits 10.2k.
If I floor it from a stop, both engines will hit 10.2k during cavitation- but the starboard will settle down to 9.8k once it catches. Port will settle in and remain at 10.2k.
they seem to idle fine- no issues with a miss or anything.
outside of coils, what else should I check?
Is the cavitation when going full throttle from a hole shot normal? When do the impellers and related bits need to be swapped?
Just replaced plugs
