NewBoater
- Virginia Beach
- 242X E-Series
Fellas I'm trying to figure all this out so any help is appreciated.
It's raining cats and dogs and the Boat is normally in the boatel when it rains as I normally get it out during nice weather. It will be at my My house docked for another 24 hours and even more rain in the forecast.
So when It rains a lot where does all that rain go in the boat? There is a hole by the engine hatch and if you open the hatch its a white tube that takes that water somewhere out the back of the boat. Is that the water (rain water) that drains by the jet l nozzles when I open the drain plug when cleaning the boat?
Bilge pump gets rid of the water in the engine compartment only correct? I noticed a minute ago when I went out to the boat that the engine compartment has a little
Water in it also and I'm guessing it's from all
This rain so not sure how it got in there as there wasn't any water in there this morning.
Someone please help and explain all this stuff to a newbie and it would be much appreciated.
Yesterday when I started the boat water sprayed out the holes on the side of the boat and I can't remember it doing that before. Is that engine water coming from bilge pump being on?
With lots of rain for 24 hours do I need to be worried about the boat taking on too much water without a cover on?
Should I run the bilge with the boat not running? To empty the water out of that engine compartment?
Thanks in advance for the info!
