cybuch
- Gilbert, az
I had to have one of my motors rebuilt in my 2005 AR230HO. Long story short: it was an issue with the ECU sticking an injector open. This was before the flyboarding. Bought a 2007 FXHO and pulled the motor and stuffed it into the boat and has been excellent for 2 years flyboarding so far.
I finally got the old motor back and it won't start, just back fires like the timing is off. I checked: the cam timing and that is good, bad fuel replaced, injectors replaced, plugs replaced. So, I thought, maybe the woodruff key broke (I know its a new rebuild). While pulling the Rotor off I noticed it was for a 6D3, not a 6B6 engine. I checked the part numbers and they are different, any idea if the 6D3 is different on timing than the 6B6? My guess is, this is my issue and need them to send me the correct rotor?
Thanks for any help!
