Question on install on 2017 Yamaha Limited SE
TSX1017
242 Limited S E-Series
I am doing a stereo upgrade on our 2017 Yamaha 242 Limited SE. I had a few questions about the factory Polk system. I located the Polk module and I see speaker wire. I have not seen anything with RCAs. Trying to locate the inputs/outputs. I have done some searching and it seems like the newer Yamaha’s have the fusion unit in the transom with the RCAS. I have looked behind the helm with no luck.
Are mine in transom remote as well.
I’ll attach some pictures of my findings. Pictures of the Polk unit in the cockpit dry storage, behind the helm, and transom Polk unit.
Thanks
Sounds like you'll need an amp with speaker level inputs or use a converter that will drop the speaker level to line levels for the new amp.
A DMM will be your friend here, if you can't find a wiring guide (even though I would still double check). Speaker pairs are typically the twisted pairs (white(FL),grey(FR),green(RL),grey(RR)) and are usually the thinnest wires. I would start there and identify those, measure for ~4ohms resistance with everything turned off.
Once you identified those, there shouldn't be too many wires left. The next identifiers are power/ground/remote. Find those three and mark those. What is left, in theory, should be your signal wires. They might be high or low voltage. I would disconnect the speakers then run a 1khz test tone through the radio and fade/balance in each direction to determine which wires correlate to the which signal. (F/B or L/R).
