Ronnie
- SF Bay Area
- Limited S
Hey guys,
I have a 2010 242 LS with the stock dual battery charging system (I.e., four modules, including main battery switch, house battery switch, combine switch and dvsr (?)). I also have a 2 bank on board charger maintainer by guest that puts out 5 amps per bank. Whenever my boat is not on the water the guest charger is plugged in doing its thing.
It's time to replace my batteries, I already bought two high cca/Mca cranking batteries but can exchange one or both of them for deep cycle batteries instead. The manager at the interstate battery store says keep a cranking battery for starting the engines and exchange the other one for a deep cycle to power everything else.
Questions:
1. Should I go with the advice above and run two different types of batteries?
2. Should I run the same batteries? If so what type, cranking or deep cycle? Why?
I like the cranking batteries because of the specs but read that our engines don't need it so I should go with deep cycle instead.
I also don't know if the stock or aftermarket charging systems require the same battery type / specs to operate properly.
Please reply.
Questions:
Please reply.
