WaltB
- Scarab
- HO Impulse
Hi Ron,
I see your knowledgable posts in this forum and wanted to ask you some questions. Just for an introduction, do you work for Scarab or are you a Scarab dealer?
Thanks,
Walt
2016 215 HO Impulse Wake:
1. I have two towing attachment points. The one at the top of the the tower and the one at the back of the boat. What are my limitations on the tower attachment? Only tow wake surfers with this one?
2. On the back of the Viper II circuit board there is a Wi-Fi antenna. (Labeled Wi-Fi) What is this for? I connect my phone to the system via BlueTooth so I’m curious what this is for.
3. Where does the factory put a second battery on the 215 HOI wake boat? I am interested in installing a 2nd battery but am not sure what location to use. (The wake ballast bags take up the compartments on the sides)
4. The new towers on the 215 HOI, 2017> use metal poles angled to the front for additional tower stability under speed. My 2016 has straps. Can my boat be retrofitted with the poles or were there changes to the tower to allow the installation of poles in the 2017> models?
5. The wet storage area at the back of the boat does not drain statically or while underway, what is the fix to this problem? I have confirmed there is not obstruction by sticking the garden hose in the hole and under pressure, pushing water through the hole and out the drain under the boat.
Thanks,
Walt
