WiskyDan
- Jackson, WI
- 242 Limited S E-Series
....sorry for another one of these but it should be quick.
So, my boat is dry-stacked so working on it is a bit of a challenge unless I do it on the water. The place that I have it does allow me some latitude but you're not supposed to really "work" on it because they have to get it out of the stack and put it outside on a bunk. My hull has some light oxidation and water marks so I want to get it cleaned up and they will allow me to apply wax but asking if I can bring an orbital polisher to remove the oxidation is going to be a stretch - plus I'm not sure I want to tackle that in their lot.
So, they said they could acid wash the hull for me and then put it on a bunk for me to finish it off as long as it's not sitting out their for days. This is my plan but I'm not sure if I have the steps correct - even after reading the other Rejex threads:
[HASH=3746]#1-[/HASH] Nice service guy at marina acid washes hull and places it on outdoor bunk where it's shaded in the morning.
[HASH=3747]#2-[/HASH] Grumpy Yamaha owner applies a wax-less polish to hull (Mequiars M4516) while shaded and under 85 degrees.
[HASH=3864]#3-[/HASH] Grumpy Yamaha owner applies Rejex while shaded and under 85 degrees - lets it cure for 12 hours, more likely a day or two.
My big question is do I have to use a polish in between steps #1 and #3 or can I just apply Rejex after the acid wash? Is an acid wash enough to get the hull ready for polish and/or Rejex?
I'm hoping to avoid step #2 as that will involve the orbital polisher but if that's what I need to do then I'll grovel a bit and see if they give in.
