ncnmra
Jetboaters Commander
- Ontario, Canada
- X
The stock headunit on my 2008 212X finally gave up the ghost, and I was excited to replace it with a new Sony unit that has bluetooth built-in. To my dismay, the "Marine" unit does not retain any settings (including BT pairing!) after the battery has been disconnected.
I have a dual battery system and a switch to disconnect them.
Has anyone ran into this issue and has a fix? I'm considering running a small dedicated "standby" wire to the battery input of the unit to retain its settings, and then have a relay that will engage with the master switch to disconnect the standby wire, and connect to the main battery wire.
I've read of some people installing a small standby battery, but that seems crazy overkill.
