- Northern Vermont Lake Champlain
- Boston Whaler
- Other
Ok, Not trying to whip a dead Mule but it is another water drainage issue with an 07 AR230. Last fall I posted about water visible in the ski locker drain and how high I had to jack up the trailer to drain it out. This is not about that now. It is about the boat sitting at the marina in the water. Water does get in under the bow cover gasket at the transition below the port side windshield. It then runs forward to the bow where the water will find level to the ski locker hatch. The depth is nearly 3/4" at the front of the bow floor and tapers to nothing at the ski locker well. Clearly the design is flawed and the water flows the wrong way and not out the scupper. Nothing heavy up front. Do the newer boats do this? There are a few ways to approach the problem. 1. Do not let any water get in the boat. Using the factory mooring/towing covers everything, the wife says no, we paid a lot of $$ for custom, so next option. 2. Install an automatic pump with suction tube in ski locker drain and just let the water accumulate there and pump it out. These 2 options are just accepting the design flaw and putting a bandaid on it. Bringing me to option 3. How much weight is needed via ballast bag on lower swim platform to change the cockpit draining to drain aft instead of forward. As my wife and I stepped onto the platform, totaling about 330#s we saw the water drain from the bow towards us. Thinking about adding ballast of 350-400# to correct deck drainage issue. This would only be used while docked at the wet slip and would help bilge water flow back to the pump to then be pumped out. The pictures are hard to see water levels but there is 3/4" forward of the carpet snaps, and the forward edge of the ski locker well is overflowing.
