Augieol65
- Downers Grove
- Limited S
Almost done thanks to everyone’s help with the raw water wash down for the dogs and the boat. Through hull placed on the rear and piped to the engine compartment where the pump is located. That is plumbed to a quick connect fitting I placed in the spot the light pole goes on the SX models. Looks good I believe. I have the pump on a switch even though it has a pressure switch. No need for it running or pulsing when I’m not using it.
