Rec needed for torque wrench
granpachuck
Cary NC
242 Limited S E-Series
Wondering if anyone cares to share ideas for torque wrenches? I think it would be handy for several jetboat tasks like pump re installation. Is there a need for more than 1 size, or range? I don't see myself using this that often, so probably interested in a mid range product.
Thanks for any help you may be able to offer.
The hardware store brand ones (Craftsman, Husky, Kobalt) seem decent and aren’t outrageous.
If you only want to buy one I’d get a 3/8 that goes from 5 to 80lbs. That would cover most maintenance type bolts on the boat.
I have Tekton torque wrenches. They are relatively inexpensive, and hold calibration well as long as you don't beat on them. I have a 1/4, 3/8, and 1/2 drive version. Litlte one goes down to like 12oz-in, and I think the big one goes up to 250ft-lbs. Will get you about 99% of the stuff you need around a jetboat or automobile. Only thing I couldn't get was the flywheel to crank bolt on a 1G RX7, spec was 750ft-lb. I guess my weight at 180lbs, and did the math for how long the breaker bar needed to be.
For little uses I just go harbor freight.
Honestly this isn't bad either. Torque is usually +/-15-20% in regards to relation to clamp load. Harbor Freight wrenches should be within that range easily enough.
i don’t have any testing with it but mine seems to work well. I use it a few times a year at most. Was hard to justify $100+ when I can grab it for $20
