Recall Notice - AR190 Fuel Tank/Fuel Pump?
Seattle-Wind
Another poster mentioned that he received a recall notice from Yamaha for his 2021 AR190 regarding an issue with the fuel tank and/or fuel pump. Since the 2019+ AR190's are the same mechanically (as far as I'm aware), this will likely effect my 2019 AR190 as well. Does anyone have any additional information on this recall?
Same mechanically, but many times a MFG may switch to a different component supplier, or change the design of particular components and have no need to inform the customer if there is no significant benefit to them. A fuel pump or component would qualify for sure.
Your best bet is to have a dealer run your HID or VIN on the engine to check for TSB's or Recalls. Until then, the model years stated are only the ones effected.
Good luck.
