Numbr1Koko
- SX
What works best? I have read that "normal" soap, whatever normal is, ruins the clearcoat of the boat. Thank you in advance.
I use the stuff from Shurhold.What works best? I have read that "normal" soap, whatever normal is, ruins the clearcoat of the boat. Thank you in advance.
Any boat or vehicle soap will be fine...I use Meguiar's regular Carwash soap. Cleans regular dirt and grime. If you have tough stains from algae, weeds, or lake scum, you'll need something tougher like Starbrite Hull Cleaner or similar.What works best? I have read that "normal" soap, whatever normal is, ruins the clearcoat of the boat. Thank you in advance.
Thank you!I use the stuff from Shurhold.
https://shurhold.com/collections/chemicals/products/brite-wash
Thank you!I use Meguiar‘s Boat Wash:
Thank you!Any boat or vehicle soap will be fine...I use Meguiar's regular Carwash soap. Cleans regular dirt and grime. If you have tough stains from algae, weeds, or lake scum, you'll need something tougher like Starbrite Hull Cleaner or similar.
Don't use dish washing liquid as it may soften the tough gelcoat finish.
Different option how about no soap I use 303 protectant and I feel like the soap washes it off. What I do helps save time and leaves the boat spotless literally no spots left from washing and it’s all done at or near the boat ramp. I keep a multi use big kahuna shower in the back wet storage area and I made a second for about $35 in parts that runs on one of my drill batteries this one is left in the truck. This process is mainly for salt water, anyone that boats in saltwater knows about the dried salt that sticks to the boat after the water has evaporated on the drive home from the boat ramp. The first part of cleaning starts after the launch, the home made battery powered big kahuna is used to rinse the trailer hitting the leaf springs, brackets, boat buckles and brakes. Takes about one minute for a quick rinse and know one even notices as they wait for me to get back to the boat after parking. This process dilutes the salt giving extended life to all the trailer parts, after 25 years of boating my biggest expense has been trailer parts. While out for the day if the boat has taken on salt water spray from waves I will use the shower water and a micro fiber towel to wipe off the salt residue and just give a general cleaning to any areas like the floor. The original use for the shower was rinsing off with warm water after wakeboarding, yes it’s filled from the house with warm water before we head out. When done for the day the boat is pulled from the water and immediately rinsed off with two people we use the balance of the shower water to rinse the boat and trailer. The big kahuna in the back runs from the boats power the hose has been extended to reach most of the back of the boat. The second battery powered shower rinses the hull and trailer again. Then a car Squeegee is used to wipe 90% of the water off the hull then a quick wipe with a micro fiber towel and the boat is literally spotless and the entire process takes about five minutes. What I’ve noticed is that the drive home from the boat ramp evaporates all the water leaving salt residue stuck all over the hull requiring a good scrub to get it off especially the occasional scum line that really hardens on, this process eliminates all of that. Then occasionally I will re apply the 303 protectant the reason for the 303 is that my last boat was the longest owned and the red hull oxidized from the UV light and I want to hopefully protect this new boat from the damaging sun rays.
