Red bilge light on connext??
Sarconen10
VA
255XE
Does anyone know what it means when the bilge status indicator on the connext screen goes red. The three normal colors are white-off, blue-auto, green-on. I have had the light going back and forth between blue and red and every time it goes red it stops running. I unmounted the pump from the bracket and it doesn't look like anything is clogging the pump. Does anyone have any recommendations or know what it going red means?
Replace the bilge pump. Just had this happening. Mine would then get to green and just keep running. Just make sure if you google, take the exact model # from pump. They have different connectors.
Took our out for first time this season yesterday and had this same question. I assume this should be covered under warranty.
how did you fix
I had to replace mine when it was doing that.
