Didn't have time to elaborate. Had to pick up my son.
Anyway - remove starboard seat cushion and then reach in behind the seat back. The lower portion is held on with wing nuts - the upper portion have brackets that insert and rest on other brackets. Once the wing nuts are removed, you will be able to pull the bottom portion out towards the bow. Once the bottom portion is out, then gently wiggle and lift.
