haknslash
- Lake Martin, AL
- Moomba
- Other
So I was removing my seat to show a member some pics but when I went to reinstall the seat and slide it down somehow my swivel handle was engaged and now my seat is stuck. It will not swivel or slide. To make matters worse I can't budge it to even remove it anymore. Something is in a bind. Anyone had this happen and know how to fix it. The swivel and slide handle is wedged and in a bind. You can see it's stuck on the swivel setting but it won't budge. It makes an awful sound when trying to twist the seat.
Do the philips screws holding in the base have any adhesive on them? I am hoping I can remove th seat and base and then look under and through the bottom of the base to see what is blocking it. Anyone know if it is a straight thru cylinder?
