Briwhy
- Saxonburg PA
- Glastron
- GTS
So I started to remove the aqua mat from my boat. When removing the Mat the top layer is pealing off leaving the bottom film behind. Any ideas on how to get this off or do you think I could use fine sandpaper and scuff it up and stick the new marine mat to it. I've tried 3m adhesive remover which worked great for the glue and I also tried a 3m eraser wheel.
