Ronnie
- SF Bay Area
- Limited S
I got this trailer with a wrecked ar 240 last November and recently decided to replace my 2010 MFI trailer with it, after I “fix it” up a little.
My plan is to swap some of the parts between trailers and sell the 2010. I started by adding an Ark Trailer Jack, magnetic “D” / brake lockout key along with a locking brake reservoir capto removed the trailer guides that came with it.
tonight after work I removed the forward bunks, the black covered ones seem to be OE and they are on the verge of failing. The gray one is aftermarket and has held up well. Next I will take off the rear bunks, and install new ones. I also want to switch trailer guides, rims and tires and possibly the winches. I’m on the fence about the rampn clamp. While I’m at it I will also install a wired rear view camera on the shorelander.
