Dave burke
- Near Lake Placid
- X
Finally did it, sucked up my bow rope last week. Wrapped around the shaft enough to stall the engine. Didn’t know what the problem was right away then took out the clean-out port and saw the rope wrapped around. Pulled the boat out of the water and had to cut the rope in multiple places until I got almost all of it out. The plastic housing on the outside of the hull is also cracked.
See attached picture. Here’s my issue - a small (I believe) piece is still stuck between the shaft and the housing where it enters the boat. I tried different ways to pull it out but couldn’t. I don’t think it causing any stress on the shaft as it seems to be turning freely and the rope did not move when I had somebody crank over the engine. I put the boat back in the water and ran it slowly up to about 4000 rpms and it seems fine.
Should I just leave this alone or try to remove it? I was thinking I could pull it out in pieces with some needle nose pliers but there’s no guarantee that I’ll get whatever is stuck in housing. Also, do I need to replace the white plastic housing? Doesn’t seem to be doing much.
Any advice is appreciated. Thx
