Replacement decking
HolySmokes
Eugene Oregon
Hello all
I want to replace the plywood decking on my 20’ Koffler Bay Bee.
There is a “ soft” sided product out there and I don’t know how to source it
I don’t want to replace with aluminum
Any advice is appreciated
Daniel
Other option would be to do the metal, but put something like SeaDek over it.
Still, good wood is much more expensive than metal. And if you decide to do something special for your family, then you should not save money. If you need good inspiration, you can go to the site Millboard Decking in Maidenhead - Walsh Landscaping, and a lot of ideas will become yours in the circle of your friends and acquaintances. I personally have not used the services of designers for a long time because I realized that I can save good money. A couple of simple techniques will give your flooring the honest, professional work that you have always dreamed of. A suitable flooring made of wood looks much more spectacular and noble, and it is also warm.
The op is talking of replacement boat decking not a home project.
I know there is a cheap version of starboard that i have seen used for replacement of plywood decking but not sure where to get it or what its called.
Saw it used on an old Shipshape tv episode
