Replacement rod holders
BinbrookJake
FSH
The rubber caps that seal my rod holders have all rotted. I was hoping to just replace the caps but it appears they're a part of the whole unit (F3M-U2898-00-00). I saw Kahuna Khris's post about upgrading the rod holders entirely, which I could still do, but has anyone replaced just the caps?
If you are talking about caps on the top of the rod holders I don’t have a suggestion. If you are talking about the caps on the bottom T-H Marine has universal ones that slip on the bottom with a 3/8” drain hose on them. The only rod holders on my boat that had drains from the factory were the forward ones, the rest drained into the storage compartments, I got the T-H marine ones mentioned above and then routed the drains so they all dump overboard.
