If I do this and have the engine won't turn off, I'm attempting to eliminate the rev limiter, I believe it is faulty as when I go 3/4+ throttle the engine dies outUnplug the black with yellow strip wire from the rev limiter. That is the kill wire that stops the engine when grounded by either the ignition switch, dead-man switch or intermittently the Rev limiter.
Figured I believe, I took off the fly wheel and 1 magnet not attached and on was missing half, I hope this was my issue, any thoughts on where I can get magnets??Clamp your timing on each lead in turn. I had a bad trigger coil that dropped out at higher RPM.
