Trucon01
- Pensacola, Florida
- 255XD
Hi All,
I have a 2022 255XD and experienced my first issue on the water yesterday... Luckily, it was an easy fix, but thought I would share for others.
The issue::
Hope this helps others.
The issue::
- Port engine would start but I had no throttle
- After taking it out of the water, the port side reverse bucket could be moved by hand
- The Port side throttle cable lever (Under that black plastic cover inside the helm cabinet) was slightly flipped to 'Manual' instead of 'Electronic'
- I moved both (P + S) levers to Manual, slide the cables all the way up and then move both levers firmly in the 'Electronic' position
