Damsroy
- LI Sound
Both reverse control cable ball joint assembly failed two weeks apart on my 2016 AR240.
Was leaving the dock two weeks ago and had no or very poor steering going forward. Went back to my slip and figured out very quickly that the starboard reverse bucket was not attached to the reverse control cable anymore and that the ball joint assembly was still on the bucket. Cable was fine but the thread on the ball joint assembly was eaten halfway. See pics below. With no ball joint assy replacement in hand I simply screwed the one i had all the way (there is still some thread left at the end) as a temporary fix. Still like this on the boat two weeks later.
Two weeks later (this weekend) same exact thing happened on the port side. Same symptoms and exact same issue. Looks like the salt water is deteriorating the thread inside the joint ball assy.
In the meantime I ordered replacement ball joint assy but ordered 2019 parts # (F2C-U1460-00-00) instead of 2016 (EU0-61461-30-00).
2019 ($12 a piece) won't fit on 2016 reverse control cables. The thread size is bigger on the 2019 cable/ball joint assy
As an FYI 2016 are $40 a piece. Those two parts seems totally similar except for the thread size so not sure why such a price difference.
Question: Would the 2019 reverse control cables fit the 2016 remocon control assy at the helm? The parts number for the 2016 remocon control assy (F2J-U134A-00-00 ) and the 2019 remocon control assy (F4A-U134A-10-00 ) are slightly different but i don't know what changed between the two.
It is not really about the cost difference but if the 2019 control cables / ball joint assy have been redesigned and are stronger in 2019 I would prefer to go with the better/redesigned solution.
TIA
TIA
