huntertexan777
- Limited S
Hey y’all, the cable assembly to my left reverse gate/bucket came disconnected from where it attaches to the boat, has anyone experienced this before or know how to get it re-attached? Is this something I can do myself or should it be taken in to the shop? Attached a couple pictures showing the issue. Thank you
Edit: the piece that screws into the boat appears to have forcefully popped out. Not sure if the threads are stripped because it can slide back into the hole without blockage. Is there a nut that is supposed to fasted onto the other side to hold the boot in place?
