Reversed Battery hook up on house battery
Jboater
X
I hooked up house battery wrong. What did I kill? No electronics, engines will still start.
check your fuses and breakers. Hopefully you just popped the mains.
You will have certainly blown the fuse on the positive connection to that battery. Follow the red cable it will lead to a box on the wall of the underseat area inside which you will find fuses. There is a 20 or 30 amp one in there...blown almost guarantee!
Thanks! I'll check it out. I sure feel like a Idiot for hooking it up in a low light setting and in a hurry.
