Right engine will not fire
shaner19
Changed spark plugs last weekend and right engine will now not fire. Ran through all diagnostics but still nothing. Batteries are fine and I get power. Left engine is fine.
Checked spark on plugs and no sparky
Did you check your lanyard. That will cause no spark. It's weird it's not both though.
Checked the lanyard too. It’s weird the engine fired up before I changed plugs on it
Only thing I can think of is make sure the connectors on plugs are fully seated. I would think all 4 would not be seated. I would probably look through the harness on that engine. I might also disconnect the battery and reset the computer. If you have your old plugs you might put them in and try it.
Ok took all spark plugs out, disconnected all batteries and checked old plug Darn.....
I had this prob with my port engine. Found out the clean out plug kill switch was not being pressed all the way down.
Just to confirm
The starter engages and the engine spins it just doesn't fire
Checked that, they were being pressed all the way down
If you've confirmed no spark at the plug the next easiest thing is going to be to check the kill switches
also check the throttle positioner just move the throttle back and forth a few times then see if it fires
Any update on this? Friend is having fame issue
I have checked all the items suggested so far to no avail. I have a sneaky suspicion I knocked something loose when servicing it but I can't see anything loose. Looks like a trip to the mechanic I guess. I'll post here the results.
Thank everyone for your suggestions. No lake today unfortunately.
Have you checked your ECU fuse?
I have not, but I will be checking this tomorrow morning. Thanks for the tip.
@Gym I am going to look at friends tomorrow same issue their port engine wont star though.. ecu is black mounted box at back of compartment correct? Will there be multiple fueses or just one?
@Wisefam22 what year and model boat are you going to look at ?
