Williamsone46
- Lehi, UT
- 255XD
The second and third picture show the spark arrester that was removed.
Is that legal? I thought there was a requirement to have a spark arrester on inboard boat engines. Maybe I'm thinking of something else...
I am not certain but I believe that All normally aspirated 1.8 liter Yamaha marine engines use the Same intake modification / part number. I recall that someone here discovered that the supercharged engines use a different part number because the size is differentt/bigger for the supercharged engines.
No they are not. 1.8l 2015 intake manifold is different than 2016, with different ribbon diameter.
@Nick Hughes I would check the part numbers (throttle assembly, ribbon) of the exact boat model number in one of the microfiche suppliers.
I don't think there is a difference for CARB models, but you will find that in parts, too.
Flat out removal of the stock arrestor and not putting anything in will give you some gain but then you kill the flow (turbulence again and it matters!) when the lip the arrestor was sitting in (see his third pic) comes into play and kills the laminar flow.
@Greg M There is a (very) strong consensus on the benefits of removing the ribbon (in 1.8l engines), but I am not so sure there is a consensus on any benefits of replacing it with the RIVA ring. Some put it in, some don't. I don't think there is data out there showing additional benefits of inserting the ring, on top of removing the ribbon. Please correct me if I'm wrong.
Of course you are right, in theory, about the air flow. However, when it comes to these engines and pumps, things that make theoretical sense rarely work in practice.
It is all a game of figuring out what the limiting factors are.
