Rdavis0207
- SX
Hello all, recently took my 08 sx230 out and port motor idled a little rough but then choked itself out around 5krmp. Took it mechanics and they have ran yds and swapped everything from good motor to bad one, ran compression, timing and everything under the sun. Says its getting fuel and spark just not spark at the right time. The only 2 things left are fly wheel and a sensor under the motor. So he is go na have to pull the motor. Has anyone had a similar issue? Ecm is good a d he has ram ohm test on everything and all reads out good per manual
