vxooxv
- Harrisonburg, VA
- SX
What.. should be the top end RPM for my boat. Generally speaking that is?
At full throttle my Starboard seems to max out at 8500 and the Port 8000. BTW - what should my max be? I probably can't quantify the next statement but I suspect the Starboard is always a little higher. I just figure that one lever is slightly out of manual hand sync than the other.
Doubt it's the plugs as I put in all brand new NGK Iridium IX CR9EIX at the beginning of the season. Is this just normal with dual controls w/o perhaps the @JetBoatPilot throttle sync?
Secondly - I pulled my first wakeboarder / skiier / kneeboarder. It was darn near impossible to keep at the same speed. I was constantly trying to adjust. I understand the whole getting outside the wake and cutting into the water will add more resistance but even straight pulling seemed to fluctuate. Is this also just a normal symptom of jet boat w/o perfect pass or something like that?
