Rule 500 Bilge Pump -Factory installed pump failure/replacement
InmyElement
Upstate, NY
X
Out the other day and the bilge pump wouldn't pump or turn on, but had power to the helm switch. Nothing stuck just locked up, pretty sad for a 4 year old boat.
So, what do I do but replace it with another Rule::winkingthumbsup"
Rule 500 GPH 25SA Electronic Sensing Bilge Pump-500
Learn more: Amazon.com : Rule 500 GPH 25SA Electronic Sensing Bilge Pump-500 : Sports & Outdoors
Our (2016) original pump had a 2 wire lead connection and this one came with a 3 wire setup. Manual (brown), Automatic (brown and white), and Negative (black). I never felt comfortable having the bilge pump switch on for the pump to run automatic and when you switched it off, it was really off. I don't moore normally, just trailer. During week long vacations it was in the water the switch was on all week, didn't seem right.
I connected the automatic side to my 12v distribution panel, so when I turn the main power on its on auto (senses every 2 1/2 min for water) then connected the manual to the original lead to the helm switch, so now I have a manual option (full on). This option I like, so when I'm cruising and water level rises for auto to kick on, the light on the dash switch lights and lets me know its pumping even though the helm switch is technically "off". Pretty Nice..worked out well. After having the scare of being out on the water with no bilge and reading within the fabulous forum, I decided to install a secondary bilge just next to the factory thru hull transducer:
SEAFLO Submersible Automatic Bilge Pump with Float Switch (750GPH, 12V)
by GK Wholesale www.amazon.com/dp/B07Q2F9QZ5/ref=cm_sw_em_r_mt_dp_U_9XLbFbJ1X0VCE
I have this pump strictly on automatic with its internal float switch. It was easy to install just ran another 3/4" tubing to an additional outlet next to the engine water pissers..
Hope this helps anyone that has to replace the original and thinking about adding a second one. If I didn't have my Tsunami ballast pump with me, I would have been self bailing, cause I dumped some of my center floor locker ballast into the bilge..
Happy Boating!
858802B1-3289-4391-8BC3-D79B040EDDAA.jpegE375E435-118C-44CC-A7FE-BECC6CF91FB2.jpeg00FB3A9B-62F4-4069-B9BE-183C15FC646C.jpeg60164299-9EC7-412D-B4A6-9B412ABB2AB8.jpegA6FD52D8-70D9-4107-AE2F-8114AAED6B00.jpeg
Thanks for the write up.
I have “add a second pump” on my list of things to do, even have most of the parts to do the install. My thought was similar to yours, install it in the bilge.
A few questions, as it appears we have similar hulls. 21ft (‘12-‘16) To do this project, did you have to remove the clean out port panel? Also did you remove a water box? Do you recall how long your run was for the tubing? Is it rather straightforward to get the tubing from the bilge to the starboard compartment to run to the thru hull fitting?
I also like your solution with how you rewired the replacement pump.
Happy Boating!
View attachment 125348View attachment 125349View attachment 125352View attachment 125353View attachment 125354
Can you send pictures where are you tied to 12 V power two for auto activation
Sure give me a day or so....
Ok, just put the brown and brown and white together to positive (factory brown) and black to black and everything works as factory… ??
So, I was actually wondering about doing this but it contradicts the installation guide. I was afraid to do this but it makes sense and it should work. Honestly, I was hesitant about the computer control issues. Did you actually do this and it worked or are you offering a suggestion?
Every season multiple boats have the engine bilge fill with water. Cheap and simple water alarms are a must have with these boats. I ordered a 3 pack on Amazon for around $25.00 includes 9v batteries still have the original from 4 years ago gave one to a friend and have a back up. Simple install with zip ties hang the sensor 2 inches above the bilge pick up. If it rings you know way ahead of time something needs to be dealt with.
