Owner of 2001 ls2000 and recently had to hobble in approximately 14mi on single engine. What action should I take, look for or expect before I perform Maintenance?
Id spray wd40 in each cylinder spin it over. Than spray again (wd40 is supposed to absorb water and lubricates). You should be fine. was it fresh or salt water? You can check oil it won't be milkey because you didn't run engine. Water will be on bottom of oil pan. If oil level is high could be sign of water in oil. But if no water in cylinders you should be ok. Other than what ever shut engine down in first place.
You don’t have oil as this is a 2 stroke so disregard the part about checking for Milkey oil. I would take the plugs out, remove lanyard, and then turn overproduced engine to see if water comes out. Next I would get it on the water and run it for awhile. Did you figure out what is wrong with the engine that it wouldn’t start in the first place?
Good info, very helpful. I’ll be back next weekend to tinker with it and get her up and running, meaning it’s been setting for about2 weeks. We were in fresh water on TRL.
Is it possible mixing a higher octane fuel with reg 89 O could cause the plugs to foul?
I made it down, pulled the plugs and turned it over, no water, replaced the plugs and fuel filter, still doesn’t start. New problem during this, changed fuel filter on starboard engine and now can’t get fuel to filter. No issue with flow on port side.
Does the boat need to be in water to run? I was under the impression it did not need to be, just can’t run it long.
I’ve checked the lanyard for connection and the rear hatch switch. Could the rear hatch switch be defective and I not know it?
@jdjetboater you can run your boat out of the water as long as you have a hose attached to the flush port of the motor you're going to run. Be careful not to leave a hose running on a motor that's not running. Remember Motor on, then water on. Water off, then motor off.
With regard to your inoperable motor. Does it crank when you turn the key? Do you get just a clicking sound when you turn the key? Does the other motor start right up? How long have you owned this boat?
Both motors crank and right now neither will start up. Previously the sbd eng was fine, now no fuel with change of filter. Port just shut down last time in water, had to wake spd home on sbd. First year of owning and has performed well when running.
I would dbl check you actually have gas in the tank. If you do sounds like fuel pump might be bad. If engines aren't getting fuel they aren't going to run.
Whereas both motors crank your rear hatch switches are ok. You should check your lanyard switch. On older boats the plastic clip or the switch itself may be worn. Try shimming it up a little higher. If still no start you should check for spark at each plug.
- see if you have spark at the plug using a spark (plug) tester - cut the problem in 1/3
- then you need to see if you have fuel - you can remove the spark arrestor on top of the carbs and shoot in some starter fluid but I would use something intended for 2 strokes
