FirstBoatRock
New to boating, first boat, even newer to JetBoats. That said, I bought a Yamaha 2014 AR-192 supercharged boat from the original owner. I've had it for about 2 weeks and learned a lot already about not letting the tow rope getting sucked into the intake.
Anyway, boat has been running fine until the other day. I can run it for awhile, 20-30mph, no problem, about 20-30 min, then it starts to get sluggish. I mean really sluggish. I can go full throttle and it takes a LOT of slugging to get to 10mph. I don't get any warning lights, I check the intake and there is nothing there. I am getting cooling and water coming out. I am getting bilge just fine. I don't have any water in the engine compartment. We got the boat from them as they were bringing out of storage and ran into this during the testing of the boat, but put more gas in, and the thing ran fine.
I keep at least 3/4 of a tank in. I've run it to just below 1/2 in the last 2 weeks but put new gas in again recently. I can do no-wake mode just fine up to 2 clicks on the button.
Any suggestions? Also, side note, I can't get the plug out to see the impeller from the top, I have to always go in through the bottom, so any suggestions for getting that thing out would be great as well. pull and pull and pull, no such luck. I even put saw horses above and tide a roap between the saw horse and the handle, using a bar to try to twist it out distributing the pressure.
Thanks in advance.
Thanks in advance.
