RXT-X 300 Stereo
ScarabMike
Green Cove Springs, FL
I needed some tunes. This thing is LOUD. I added a sub, and it sound awesome. Tell me what you think guys.
Here is a list of parts that I used.
1. 1/4" starboard. Made a copy of the stock access panel, and shaved the edges to slide into the grooves in the liner. Then I drilled holes to match the stock ones. I used stainless steel hardware to hold the top.
2. Alpine KTP‑445U in 4 channel mode with the rear channels bridged for the sub.
3. Kicker 5.25 powersports (4 ohm)
4. Cheap PYLE 8" sub. (i'll be upgrading to a JL soon with a separate amp)
nice. Interested in this amp for my golf cart to push 4 polk db651's that came out of my boat.
@ScarabMike how does the amp connect to a music source? I am about to order one but want to make sure I can connect to my iPhone somehow.
cool thanks! And amp wires to battery using amp wiring kit correct?
I used a #6 ground and positive to a new fuse panel from Sea systems. Mounted a switch in the glove box, and made that whole fuse panel a switched power distribution block.
