Sanity Check on new stereo wiring config
Diablo243
Southeast CT
Ok replacing the stereo and speakers in 2013 242ls, have the 6 speakers the boat came with plus a pair of tower pods. Running an 8 channel amp and will be adding 1 or 2 10" subs. My amp is 2ohm stable and the speakers are all 4 ohms, my thought is to take the swim and tower and put them in parallel on the rear channel and the bow and cockpit in parallel on the front channel. Bridge the other 2 channels for the subs and call it a day, any see any gotchas or have a better idea than this? thanks!
sounds fine to me. you will get more power that way too.
@Diablo243 Yup, shouldn't be an issue. But just to clarify you don't really get any more "power" output in the form of volume. When you parallel speakers, the amp may put out twice the wattage, but the speakers then divide that power in half for each half of the connection. Net result is the same power to each speaker whether direct or parallel. You can get a bit more overall volume since you may have more speakers running on the same channels in the same area, but you don't double output. It's not an issue at all and I have done the same thing with my system, running 8 speakers off a 4-ch amp keeps it simple.
@212s don't want to argue but my practical experience tells me it does increase the volume somewhat, but not double. I have tried it both ways numerous times over my many system installs over the years, and it always sounds better at the lower impendence if the amp supports it. The two speaker act as one.
ref: https://geoffthegreygeek.com/speaker-impedance-changes-amplifier-power/
