FLJetBoater
- 242 Limited S E-Series
Hi guys,
so again this weekend I had another starter crap out. Press the ignition and can just hear it spinning and not engaging.
Last time I took a starter back to SBT (2nd time for the same part in 6 months) they told me they wouldn’t warranty them anymore because they weren’t having other returns at the same rate as mine, and that it must be caused by my boat.
However, it’s happening on both engines. Are these starters just not up to quality/durability as the Yamaha OEM ones?
What’s happening is the starter gear and piece it attaches to that sticks out of the starter are stripping. There’s no other issues with the engines that I’m aware of and simply swapping the starter for a new one gets me back up and running.
so questions….1. Is this just a quality issue where the fit between the gear and pole isn’t tight enough or 2. Are my engines somehow creating a greater force on the flywheel that’s causing these starters to strip?
pics attached of removed starter vs new starter.
