PeterJB
- Scarab
- 165 ID
All,
I have a Scarab 165 HO and experience some problems with the bilge pump. The bilge pump worked a few days ago, but today it is dead. When I manually try to start the pump nothing happens. The red light on the Bilge pump switch in the helm is not going on when I turn on the switch. All other switches are working and the red light are on when switching. I have tried to change the bilge pump fuse (C3) in the helm of the boat, but did not help. I know it is another fusebox close to the battery, but which fuse goes to the bilge pump (if any)?
As the red light is not on i suspect it must be something wrong with a connection before the pump. Anyone have any idea on what I should do to continue to locate the problem?
Kind regards,
Peter
Kind regards,
Peter
